Order Ford 8N Parts Online
'46 2N with early 8N motor
Dana
04-11-2002 16:08:24
I have a '46 2N with an 8N motor. I know (believe) that it is a '46 because the date stamps on the rear axle housings are from April and June of '46. As far as I can tell, the engine has no serial number. I have scratched the paint off the spot where the serial number should be, and there is no number. The only numbers I can find are on the block near the starter. There is a little sheet metal tag with the id "N A2 1" held to the block with two little screws. Just below that, there is a rather large "8N-B 1" cast in the block vertically. The distributor is in the front. Anyone with ideas as to what I've got here?
Ray Oh
04-12-2002 05:03:40
 Re: '46 2N with early 8N motor in reply to Dana, 04-11-2002 16:08:24
I Have One Like That.8N182649 On The Motor. Front Mount. 3 Speed Everything But The Motor Is 9N
don b
04-11-2002 17:48:49
From those numbers,you have a 51 8n engine that has been converted to a front mount distributor.A21 means Jan.2 1951.Hope this helps, don
Dana
04-11-2002 18:48:08
 Re: Re: '46 2N with early 8N motor in reply to don b, 04-11-2002 17:48:49
I wonder if the guy bought a replacement engine that did not include a distributor, and then used the original 9N distributor. Would this work? Is it possible to identify the distributor?
Dave Smith
04-11-2002 18:54:45
 Re: Re: Re: '46 2N with early 8N motor in reply to Dana, 04-11-2002 18:48:08
The cam would have to be changed also. The side mount has a gear on the cam to drive the distributor.
Dave <*)))><
MikeC
04-11-2002 17:43:17
This may be a stab in the dark, but any chance someone may have purchased a rebuilt motor and replaced the old one with it? I remember a discussion some time ago about a similar situation and it was determined that some rebuilders remove the original serial number and replace it with theirs.
Dana
04-11-2002 18:41:42
 Re: Re: '46 2N with early 8N motor in reply to MikeC, 04-11-2002 17:43:17
I was told that the seller's father-in-law had replaced the engine some time ago, but I don't know where he got the replacement engine.
Upper Michigan
04-11-2002 16:14:10
Dana. Look to the left of this colume under Research and Info. You will find Production Nbrs,& Serial Numbers.Click on them. This should answer your question. Ron
