2n
war time model noisey gears ??
BURT
04-14-2002 17:52:22
1942 -2n its been here 2 years, haven't put the steel wheels on yet, so I drove it to coffee shop (it has sherman overdrive?), everything works good but gears are very noisey???
Truck
04-15-2002 07:52:34
 Re: 2n - war time model noisey gears ?? in reply to BURT, 04-14-2002 17:52:22
Just wait till you install the steel wheels and the gear noise will be much less of a concern.
I think my step up sherman whines pretty good in high 3rd. Do you have a front crank? ANy chance I could get a picture with dimensions? Thanks
(Also have a SW War model)
Steve W
04-15-2002 06:26:36
As others have said, straight cut noisy gears are standard on 2N's and 9N's, but they get really noisy when you lose a tranny bearing.....best thing to do is find another N to compare with.
take Care
Steve
roperboy
04-14-2002 19:48:04
hi burt, i think sherman overdrives are just naturally noisy in high range. i have one in my 47 and when i did the rebuild/restore on the tractor i took apart the sherman and inspected it and found no wear. its still as noisy as ever now in overdrive.
2NTim
04-14-2002 18:45:05
Burt,
That's the nature of straight cut gears...they were changed when the 8N came along, I think.
