Crank driven hyd pump question
Paul
04-15-2002 09:15:16
Just bought a loader at an auction, and it came with the small hydraulic pump mounted at the front, with a flexible coupler and the splined shaft on the tractor-engine side of the coupler. I assume somebody makes an assembly that replaces your crank pulley with a splined-center type of pulley? Is it a two-piece affair, so you can get to the pulley bolt, then bolt on the splined part to that? Does anybody have such an assembly used? I think my shaft is a 3/4" diameter, six spline type, but I'll have to verify that. Failing that, where can I get this setup aftermarket? If I just want to get the outer part, and use my original pulley, is it stout enough to drill in the 4-bolt pattern (or whatever it is), to mount the splined piece? I guess I'd have to take off the hand crank spirals. Any suggestions? Thanks!
Bob /Ont.
04-15-2002 09:43:39
 Re: Crank driven hyd pump question in reply to Paul, 04-15-2002 09:15:16
Paul look in the archives, "dearborn loader" I have seen picturs posted of the set up. you need a splined coupler and a pully that can take 4 bolts to fasten it to. The jubilee had this setup and I think you can get it for yours too.
Good luck. Bob
Dell (WA)
04-15-2002 09:41:21
Paul..... ...if your N's front pully is an OEM sheetmetal assembly, trash-it. Get a replacement billet pully with 4 mounting boltholes already tapped to mount your bridged pump splined stinger adaptor. And yes, you will have to get rid of your toothed starter crankshaft pully bolt to a regular hex bolt..... .....Dell
Paul
04-15-2002 13:25:07
 Re: Re: Crank driven hyd pump question in reply to Dell (WA), 04-15-2002 09:41:21
I'm not where the tractor is right now, but are you saying the hand-starting spiral deal on the crank is actually the bolt head? Is that gonna be a huge problem to get off? Special tools and such? Can it be done with taking all the radiator and stuff off? Thanks to all who responded.
Dell (WA)
04-15-2002 16:34:55
 Re: Re: Re: Crank driven hyd pump question in reply to Paul, 04-15-2002 13:25:07
Paul..... ...to take the engine crankshaft pulley bolt out (and install) stuff as much 1/4 soft clothesline rope in a sparkplug hole you can. The crank will turn up against the blockage and you can untorque/torque the 5/8 bolt 150 ft/lbs. Piece of cake. I put the socket on the starter bolt then stuck a long extention through the radiator hole and vola' off/on it goes..... ...Dell
Paul
04-16-2002 06:12:44
 Re: Re: Re: Re: Crank driven hyd pump question in reply to Dell (WA), 04-15-2002 16:34:55
That's an excellent idea, thanks!
Hey Dell...Barnstormer
04-15-2002 10:57:37
I think when I did that with an 8N, that I once owned, I had to grind the bolt head down to get the plate on flat. I had tried it with both sides of the plate.
