Generator question
2NTim
04-15-2002 13:46:41
Which Generator is "correct" for my 1942 2N...
the small, single wire...or the larger 2 wire?
I'm confused (uhhh...not a rare condition these days, my wife says)
2NTim
Dell (WA)
04-15-2002 15:31:59
 Re: Generator question in reply to 2NTim, 04-15-2002 13:46:41
Tim..... ..your 1942 2N might have came from the factory with NO generator, or battery, or starter (something about a war?) and a magnito distributor and armstrong starter. Most were converted later on to frontmount distributor, 1-wire 3-brush generator and roundcan cutoff relay. Ford also offered a 3-wire with square regulator retrofit kit after they came out with the frontmount 8N in 1947. So flip a coin, your guess is probably better than mine..... .....Dell
2NTim
04-15-2002 18:01:00
 Re: Re: Generator question in reply to Dell (WA), 04-15-2002 15:31:59
Thanks!
I'm thinking I'll stick with what I have...cheapest that way. If it had originally had a magneto, wouldn't there most likely be a small hole in the right dogleg for the spark retarding rod? If so, I don't have the hole...and I THINK these are the original doglegs.
What a neat place this is...must be about a million years of collective experience here!
ED-IL
04-15-2002 14:17:06
My '46 2N has a single wire generator - I am puzzled as to how a 2N could have a 2-wire, given the wiring of the charging system through a cutout relay. Then again, it could be a 2N with 8N electrical system and a voltage regulator.
Hope this helped
2NTim
04-15-2002 14:30:48
 Re: Re: Generator question in reply to ED-IL, 04-15-2002 14:17:06
Mine has the single wire as well...with the round cutout relay under the battery.
ED-IL
04-15-2002 14:37:10
 Re: Re: Re: Generator question in reply to 2NTim, 04-15-2002 14:30:48
Yup - single wire for the cutout relay.
If'n other questions, let us know.
