Leaking rear end.
Plash in OK
04-16-2002 21:05:33
I noticed trans-hydr fluid leaking on left side of my 9-N. The bolts had worked lose. I tightened them, but it still leaks. The question is : Has anybody had experience of stopping such a leak without removing the whole axle housing and replacing the gasket? Thanks in advance for your advice. I really like this forum.
Dell (WA)
04-16-2002 23:30:26
 Re: Leaking rear end. in reply to Plash in OK, 04-16-2002 21:05:33
Plash..... .....NO, to fix the lower link leak, you have to take the rear axle trumpet off to get to the cotterkeyed castelated nut to tighten it to 150 ft/lbs. Soak your trumpet/diffy gasket in warm water for 15-30 mins..... ..... Dell
chris
04-17-2002 08:22:45
 Re: Re: Leaking rear end. in reply to Dell (WA), 04-16-2002 23:30:26
I had the same problem with my 9. Yup, gotta tear the case apart. It's not a real tought thing to do. Jack the tractor up just so the weight is taken off that side. That way when you break the case loose, you will be able to just slide the whole thing. Obviousely it is pretty heavy, so you might need some help to balance it.
