Order Ford 9N Parts Online
9N Starter Problems
Alex F
04-17-2002 15:53:54
a 9n, with six volt system
the starter engages and turns the motor, however, when the engine starts to fire the bendix kicks out and the engine won't fire up. we replaced the bendix but the same think is happening. You can here the starter continue to spin after contact with the fly wheel has been lost.
any idea?????
btw, the starter button is bad so we jump the contacts with a screwdriver - if this matters
Thanks alex
Dell (WA)
04-17-2002 23:06:55
 Re: 9N Starter Problems in reply to Alex F, 04-17-2002 15:53:54
Alex..... ....check your ignition timing. Remove the distributor from the block. (2 bolts). do the timing procedure per I&T FO-4, its pictures explain better'n words.
Even better is to use the newer and better clutch style starter drive just $5 more than old screw bendix which must be spotlessly clean, no oil or greese.
In the mean time, sometimes you can get the engine to start by getting the starter to turn the engine over first and THEN TURN ON the ignition switch..... ....Dell
Luke (MI)
04-17-2002 16:47:03
The ford dealer sells a new spring and retainer clip. Sounds like the spring is weak
