Order Ford 9N Parts Online
9n runs, lacks power the warmer it gets the weaker it gets
philmeng
04-19-2002 06:24:36
Ran fine two weeks ago. Now it starts fine but just doesn't have any guts. Runs smooth at idle with an occational putt, as it warms up it misses a little more frequently. When you put a load on the engine it boggs down and coughs and sputters and will die if the clutch isn't engaged. The govener seems to be working ok. Put on new air and gas filter, new plugs, cap and rotor with no improvement. What now? The grass is growing even as we speak!!!! Thanks to anyone that can HELP.
philmeng
04-20-2002 04:48:53
 Re: 9n runs, lacks power the warmer it gets the weaker it gets in reply to philmeng, 04-19-2002 06:24:36
The new coil did the trick. I also bought a set of points for a rainy day project. Thank you for the good information.
Dell (WA)
04-19-2002 08:14:36
Phil..... ...your described problem is endemic of a bad frontmount ignition coil, replace it..... ....Dell
philmeng
04-20-2002 05:03:38
 Re: Re: 9n runs, lacks power the warmer it gets the weaker it gets in reply to Dell (WA), 04-19-2002 08:14:36
The 9n runs fine after replacing the coil. thanks for the good information.
GC in OH
04-19-2002 06:50:57
Had the same problems with my 9. Put in a new coil and runs great.
philmeng
04-20-2002 04:58:39
 Re: Re: 9n runs, lacks power the warmer it gets the weaker it gets in reply to GC in OH, 04-19-2002 06:50:57
the new coil did the trick. thank you for the quick response. I was able to get in 4 hours of mowing before the rains came! Phil, Wayne County Ohio
