Plows that don't work; not your fault!
2fordsmike
04-20-2002 09:43:01
Boys: Some old Ford and Ferguson plows are too far gone! That's my impression of many or the old plows I see on scalpers' lots. I see some plows robbed of parts. And, almost universally, equipped with worn and dull and sometimes broken forged bottoms. Forged plow bottoms are not being made and are not available except as rare New old stock. They virtually impossible to find, to my knowledge. And, there are very few blacksmiths, even here in Iowa, who will repoint and sharpen these old forged bottoms. You may have to drive 100 miles to find such a blacksmith. I think I can safely say that for every 1,000 acres plowed here in Iowa, about 999.9 are plowed with plows that DO NOT have forged bottoms. Second: Virtually all scalper plows have extremely rusty moldboards. If you are going to use the plow on a garden plot of clay soil, it may take you several years to get the moldboards land polished to work as they are supposed to. I urge my amateur farmer friends to buy only those later model plows that take the so-called razor blade or throw-away plow bottoms. You can buy these replacement plow "lays" at most any farm supply store. If you have never plowed, buy a new set of plow lays (or bottoms) before you attempt to plow your garden. And buy an owners manual! When you finish plowing, grease or paint the bottoms, moldboards, coulters and tailwheel to prevent rust from forming on these parts. I've been thinking about writing this bit of advice for a year or two. I do this with the best of intentions, but there will be other opinions, I suspect. For one example, Zane has a low-cost method of repairing the old forged bottoms and I hope he will tell us once again how he does it. But I am not a blacksmith. Good luck and good plow
Gary
04-20-2002 18:54:15
 Re: Plows that don't work; not your fault! in reply to 2fordsmike, 04-20-2002 09:43:01
You're right about a rusty moldboard making a plow behave badly. It takes quite a while to polish one when you've exposed it to the elements. But once it is, it's a dream to use. I always keep some used motor oil handy and paint the shiny parts when I'm through. It'll prevent rust sometimes all the way through the off season. Maybe a little of it gets in the soil, but I don't think it's enough to hurt.
Bill MacPherson
04-20-2002 11:00:48
You are right about old Fergie plows , what you say , can be applied to any plow from 2 to 10 furrows , a lot of junk out there--Bill
Barnstormer
04-20-2002 10:20:26
Mike, you are right. A plow in excellant shape will pull like a hot knife through butter versus the dull knife cutting wire of a worn out plow.
Soil texture and moisture content, debris from previous crop or a long time fallow field also will affect the process. Sod is the toughest in my experience.
Loaded or weighted rear wheels help. A strong engine and properly functioning hydraulic system are prime.
I believe experience will help. I have been plowing since I was 10, 49 years, and certainly don't know everything about it. I have probably commited every mistake and sin imaginable with an 8N and Dearborn 2-14 plow.
2fordsmike...we're about the same vintage
04-20-2002 12:19:52
 Re: Re: Plows that don't work; not your fault! in reply to Barnstormer, 04-20-2002 10:20:26
Dear Barnstormer: I made mistakes with plows, too. But learned what a good plow was when Ford came with the truss-frame, trip-beam model 101 in the mid-1950s. Ours came new with 18-inch notched coulters and dad said, "It would plow through a baled straw." It couldn't, but it would do great work in many conditions. I have a little 2-12s model 101 in the shed that anybody could plow with. Its kind of like having a kid-broke horse! Mike-Iowa
Like wine, vintage ;) Barnstormer
04-20-2002 19:54:56
 Re: Re: Re: Plows that don't work; not your fault! in reply to 2fordsmike...we're about the same vintage, 04-20-2002 12:19:52
I'll remind my wife. ;>)
