Order Ford 9N Parts Online
Is it a 9n or 2n??
Otis M. Mims
04-23-2002 20:20:12
I have a Ford Tractor serial nr. 9n *I88446*. Is this a 2n or one of the last 9n's? do the serial numbers overlap from the 9n's to the 2n's. Thanks for any help with this, I figure one of you "In the know folkes" can tell me.
Tom-Pa
04-24-2002 06:31:59
 Re: Is it a 9n or 2n?? in reply to Otis M. Mims, 04-23-2002 20:20:12
9N and 2N serial numbers all start with 9N. The 9n serial numbers go up to about 99003 or so and the 2N's start from there. a 45 2N is about right. Good luck with your 2N
Tom-Pa
Jay 2NSC
04-23-2002 21:03:50
Hi Otis,according to all of my info,you have a 1945 2N.You can look to your left under Research and Info,scroll down to Serial Number's and see for yourself.Hope this helped. :^) Your friend,Jay 2NSC
Jays right....Rob nm
04-24-2002 02:58:34
 Re: Re: Is it a 9n or 2n?? in reply to Jay 2NSC, 04-23-2002 21:03:50
'46 2N Rob nm
04-23-2002 20:33:41
Bill LaRue
04-28-2002 20:31:35
 Re: Re: Is it a 9n or 2n?? in reply to '46 2N Rob nm, 04-23-2002 20:33:41
You cant depend on the serialno. for the model year.many engines have been replaced.Check the radius rods.The 9n had an I beam-the 2n is oval.
