Sherman Trans.
Reno J.
04-24-2002 19:05:31
Does any know if the combo sherma trans as seen on the Smith site will also fit a 2/n? Are they all interchangleable? between 2/n 8/n. thanks Reno J.
Barnstormer
04-24-2002 19:17:42
 Re: Sherman Trans. in reply to Reno J., 04-24-2002 19:05:31
I think previous posts have addressed this issue. If I remember correctly, they are not interchangeable. The 9N/2N has a straight or spur cut input gear and the 8N/NAA has a helical or "slant" cut gear.
Comeon guys, am I slipping here?
semi-slippin . . . Dell (WA)
04-24-2002 19:43:31
 Re: Re: Sherman Trans. in reply to Barnstormer, 04-24-2002 19:17:42
Reno..... ...Barny's semi-gottitt right. The earlier 9N's had straight cut tranny input shaft gear, but I think they changed to helical cut sometime in late 1940 early 1941 (I've been known to be wrong).
Bottom line, ya gotta check visually, its rather obvious the differences. The tranny input shaft length to the clutch disc is the same in all N-Tractors. Its the tranny gear..... .....Dell
sliding...Barnstormer
04-25-2002 03:48:17
 Re: Re: Re: Sherman Trans. in reply to semi-slippin . . . Dell (WA), 04-24-2002 19:43:31
Goodmorning, Del.
That is a slippery slope that we walk on. I can't remember how many things that I have forgotten. ;>)
Lyle
04-25-2002 10:39:40
 Re: Re: Re: Re: Sherman Trans. in reply to sliding...Barnstormer, 04-25-2002 03:48:17
Hi, FYI, I have a 1942 2N which has the Sherman Step Up transmission installed. So at least the 42's and I assume the one's after that will work.
Hope this helps.
