Clutch stuck to flywheel
9-n Rookie
04-24-2002 20:10:41
My neighbor left his 9-n out in the winter rains. Now he wants to use it and the clutch is stuck. Can it be freed without splitting the tractor.
Thanks Rookie.
Greg (NV)
04-25-2002 08:33:30
 Re: clutch stuck to flywheel in reply to 9-n Rookie, 04-24-2002 20:10:41
There was some recent discussion on this very same topic so you may want to check the archives. Hope this helps.
Greg
Nevada
John,PA
04-25-2002 05:37:28
Probably you should plan on splitting the tractor to free-up the clutch plate. Good time to check other things, too. I fashioned a wooden block to keep the clutch pedal depressed during periods of non-use.
