Rookie..... .....I funked mindreading, just ask my exwife. So far we've established you are a certified ASE mechanic that hasn't worked on automobiles for 5 years and you can't figgure out to get a 60 yr old tractor designed for horsefarmers to run. We've also established that you have water in the cylinders and that you have thrown a lot of new parts at your tractor and it still doesn't run. And we've also established that you took a running tractor into a tractor dealer and paid $470 for unspecified work and now the tractor doesn't run. And you don't know why. Oh yes, we've also established that you have the I&T FO-4 manual. What we haven't established is whether you have the triangle, Fuel, Ignition, Compression. We're not off to a good start here are we? Compression, water in cylinders, cylinder headgasket, fix it. Ignition, does it cough on ether quick start? No? fix your sparkies Fuel, does it run on ether quickstart? yes? its your self-rebuilt carb. I'm outta ideas..... .....respectfully, Dell
