PTO Update
Arne - Idaho
04-28-2002 08:32:56
Well, didn't do any work to the PTO. But did do a lot of work to the brush hog. It was running so rough, it was causing the PTO to disengage. I still think the PTO mech is worn, but should do okay for a bit. I will test the tractor on the hay rake and see how that goes.
Arne
Dave Smith
04-28-2002 17:19:13
 Re: PTO Update in reply to Arne - Idaho, 04-28-2002 08:32:56
Arne, You say it is running rough and talk about the PTO. Do you mean the engine is running rough or you have a lot of vibration from the PTO. Do you have the PTO shaft in phase? Samie, sames together?
Arne
04-28-2002 19:41:19
 Re: Re: PTO Update in reply to Dave Smith, 04-28-2002 17:19:13
Dave,
The implement was running rough. Tractor is fine. The hog's power unit was loose, the 3pt pins were loose, the blades were wrapped up with hay twine, etc. Got the hog all re done with new bolts, all cleaned up, sharpened, etc. Works good now. :-)
Arne
