Rattle can primer question
Alan
04-29-2002 09:57:00
HELP..... I need to paint some small parts ...Some are rusty some are not ....I intend to sandblast....and I am confused about when to use the red primer (red oxide) or the gray....The cans don't say much on them and the guy behind the counter don't know...I read thru the archives and altough there is a wealth of info there I couldn't find an answer....Is one to be used on rusted surfaces and the other on non rusted surfaces ...if I sandblast rutsty parts are they considered non rusted..... Somewhere I thought I read that the red primer has some sort of oil in it and is meant for rusted metal only , and f you used it on non rusted meatal the top coat would not adhere to it well....As usual any opinion greatly appreciated...Thanks...Alan
John Smith
04-29-2002 14:56:19
 Re: Rattle can primer question in reply to Alan, 04-29-2002 09:57:00
There are several different types of primers for different applications. As for the red and gray color, that's usually determined by the topcoat color. Dark (red oxide) primer under dark colors, and light (gray) primer under light colors.
John,PA
04-29-2002 11:47:45
The old fellows that I studyied under always agreed that primer was basically used to fill the pores of metal. Primer was cheaper than using finish color for building up for a smooth finish.
Aluminum is another story.
I think that I would be sure that whatever medium used to keep metal from oxidizing, make sure that the primer, if used, is compatable with the finish coat. Enamel or Lacquer. :)
Greg (NV)
04-29-2002 11:05:03
Alan, I sanblasted my rusty parts, and trust me, there was no more rust when I was finished. Just clean bare metal.
Greg
Nevada
Barry N Indiana
04-29-2002 10:59:47
Alan:
I was under the impression that the red primer was "sanding" primer. used during body filling work. You work the Bondo down by sanding...spray with the red primer and sand it lightly and you can then see the high and low spots...
Barry N Indiana
Luke MI
04-29-2002 10:28:22
Alan, I am not aware of primer made to go over rusted parts. My advise is if you are planning to sandblast anyway get all the rust off before you prime. It is the only way I know of to ensure the rust does not come back.
