Order Ford 8N Parts Online
8N only firing on 3 out of 4
Rich
05-01-2002 18:25:12
I have put new wires,plugs,coil,cap and rotor on my 8n and still geting speratic fire on one cylinder.I can hold the wire to the plug and it will fire several times and stop for a short while and start firing again.Pulled distributor and while turning the rotor the points are opening on all 4 lugs,bushings showing little wear.What am i over looking?
Thanks in advance..... ...Rich
DON TX
05-01-2002 20:36:39
 Re: 8N only firing on 3 out of 4 in reply to Rich, 05-01-2002 18:25:12
Check for play on the distributor shaft. Bushing wear may be the reason. Just did mine.HTH
DON TX
John,PA
05-01-2002 19:20:11
I believe that I would try another wire to the spark plug, temporarily.
If the plug fires ok, then I'd replace the bad wire.
Hope this helps. :{)
