'dem old red and grey tractors
rob 8N11071 KS
05-03-2002 07:55:41
third party image
Or is that grey and red?
Or is that two shades of grey, a red engine seat and hubs?
Oh, and while you're at it, reverse one tire tread. [*]
Grey and Red?
Red and Grey?
(* some legit reason for doing this??)
Chuck (CA)
05-03-2002 19:00:50
 Re: 'dem old red and grey tractors in reply to rob 8N11071 KS, 05-03-2002 07:55:41
It looks like my Fergie TO30 except this one has an engine in it... Mine has an engine in the barn. MARK!! I STILL NEED A BLOCK!!
Actually, I'm not picky; a Z120 will even do the job. Turns out my head is from a TO20 anyway. A lot of interchangability (sp?) on these old girls.
My paint job is also kind of a reverse redbelly.. Red tin and grey chassis. If I ever get it running again it's going to get stars and stripes. Obviously, I'm not a purist.
Chuck
BHFLA
05-03-2002 10:41:57
You question the reason one tire is backwards. Some believe if you do this you have the same pull going forward and reverse instead of just having all your pulling power going forward by having both tires facing forward. I've not tried it, just heard this explanation before.
rob 8N11071 KS
05-03-2002 11:25:54
 Re: Re: 'dem old red and grey tractors in reply to BHFLA, 05-03-2002 10:41:57
seems to me you would have the same pulling power forward and backward, but it would be half in both directions.
its a . . . Dell (WA)
05-03-2002 10:28:35
Its an Envious Fergie owner's paint job. Its a Fergie..... ..no radiator cap
Its a Fergie..... ..no rear axle NUT
Its a Fergie..... ..not a flathead engine
Its a Fergie..... ..horizontal grill bars
uh.....bg
05-03-2002 15:09:28
 Re: Re: 'dem old red and grey tractors in reply to its a . . . Dell (WA), 05-03-2002 10:28:35
I bet it has a radiator cap, you just can't see it 'cause it's under the flip-up hood!
Fred Martin
05-03-2002 11:02:31
It's a Fergy....also three little holes on rear side of hood for Ferguson badge.....if you look kinda close.
John,PA
05-03-2002 08:33:23
I'll bet the main job for the Ferguson is to push a scraper blade for pusn' snow.
Mark Hendershot
05-03-2002 08:10:18
Yup that's a Ferguson allright. It should be all grey too to be politcal correct. Mine isn't it is mostly red with some silver on the engine?? Got to change that silver some day! Mark H.
bg
05-03-2002 08:00:50
It's a Fergie. At least the gray looks like the right color.
MikeC
05-03-2002 07:58:09
Am I mistaken or is that a Ferguson?
