Order Ford 8N Parts Online
Hard starting 8N
Rikiz
05-03-2002 20:10:19
Have a 1952 8N that is one hard tractor to start.
It has been converted to 12v. I have replaced plugs, wires, points, condenser, dist cap, and coil. Have also switched the manifold and carburetor with one of my easier starting 8n's. So far, it is still a hard starter. Any ideas? The tractor is a strong runner once she gets going. Thanks, Rikiz
Dell (WA)
05-03-2002 23:03:58
 Re: Hard starting 8N in reply to Rikiz, 05-03-2002 20:10:19
Rikiz..... ....hard to start is usually an ignition timing problem or a compression problem or a fuel problem.
Without knowing your compression readings (Ford spec: 90 psi min) and based upon your claim of "strong runner", I'd guess your compression was probably OK.
And since you claim exchanging carb and manifold with another eazy starting 8N without improving the starting, I'd guess the carb is ok BUT you haven't proved that the rest of your fuel system is OK.
Give it a squirt of ether quick-start. If it buzzes right off, sparkies are probably OK but still doesn't get the timing or fuel system off the question mark. If it doesn't buzz right off, probably confirms somesort of sparkie or timing problem..... ...Dell
bg
05-03-2002 23:22:13
 Re: Re: Hard starting 8N in reply to Dell (WA), 05-03-2002 23:03:58
I was wondering if perhaps the compression was too high, like from incorrect valve clearance or too tight ring end gap or something else wierd. With the 12 volt conversion, I'd more suspect the condensor, coil, or as I stated below, timing, and advance.
phil
05-04-2002 00:26:07
 Re: Re: Re: Hard starting 8N in reply to bg, 05-03-2002 23:22:13
I don't know, when I tap the starter on mine she's runnin'. Could be the operator.
bg
05-03-2002 20:45:22
Have you checked compression? Does the engine spin over easily with the spark plugs removed? Have you checked the timing and advance mechanism?
Does your manifold have the tapped fitting for a vacuum gauge reading?
