Original Oil Filter Housing?
2NTim
05-06-2002 12:57:50
Fer accuracy in restoring my 1942 2N (9N103775), which oil filter housing is correct...the one with 7 narrow radial "grooves" on the bottom, or 4 wide ones? I've seen both and don't seem to see a pattern in year/model used on.
Were both supplied?
Thanks! 2NTim
bg
05-06-2002 18:13:56
 Re: Original Oil Filter Housing? in reply to 2NTim, 05-06-2002 12:57:50
my 52 has the 4 wide grooves, and no drain plug on the bottom.
John,PA
05-06-2002 13:25:35
Well Tim,
My '42 9N is original and it has the 7 radial grooves. Hope this helps. :})
2NTim
05-06-2002 13:32:31
 Re: Re: Original Oil Filter Housing? in reply to John,PA, 05-06-2002 13:25:35
Ya...thanks! That's the one I have. As I'm tearing it down, I'm amazed at just how many of the parts are orig...not at all the "hybrid" that I keep hearing about. I've had to buy maybe 4 or 5 parts (mostly little "detail" ones)...and have about 4 or 5 more to go to be complete.
Thanks again
John,PA
05-06-2002 18:12:35
 Re: Re: Re: Original Oil Filter Housing? in reply to 2NTim, 05-06-2002 13:32:31
I think the "coolest" thing was finding all of those attaching bolts with the Ford Logo "F" on the bolt heads.
2NTim
05-07-2002 04:27:01
 Re: Re: Re: Re: Original Oil Filter Housing? in reply to John,PA, 05-06-2002 18:12:35
k...ya made me get up off my duff and go check it out...but...no cool bolts :=(
BTW...Have you ever seen a GOOD originality guide for N's? Every book I seem to pick up has many inaccuracies...or, at least, they sure don't agree with one another.
