BRAKE SCREECH
ALLEN
05-07-2002 10:37:58
OUR 52 8N LEFT BRAKE SCREECHES LOUDLY AFTER APPLYING BRAKES.YOU CAN PICK UP ON PEDAL AND HAS NO EFFECT.I REMOVED BRAKE DRUM YESTERDAY AND CAN'T FIND ANYTHING WRONG.NOISE WILL QUITE AFTER A FEW REVOLUTIONS OF WHEEL WHILE DRIVING.I KNOW LEFT SIDE USES A EXTRA SPRING AND IS IN PLACE.COULD SPRINGS BE WEAK? HELP ME OUT ZANE !!!
darren
05-08-2002 07:24:18
 Re: BRAKE SCREECH in reply to ALLEN, 05-07-2002 10:37:58
having the same prob..
Ron
05-07-2002 12:41:18
Common problem if new brakes. Even if not new sometimes happens. Using a rough file, shape a chamfer on both ends of both brake friction materials not steel backing. Chamfer should extend about an inch from end of friction material.
