What a find
premie-farmer
05-08-2002 11:51:27
Hey I found on the back of my property all grown up in briars and covered a McCormick-Deering No. 7 horse drawn mower all rusty of course with the pittman arm rotted but I slipped it in gear and the gears all moved when I moved it around and the flywheel moved. Can you use one on these with the 8N? If so would I be able to refurbish the missing wooden pittman arm? It sure would make cutting these brias easier as the thing has got to have 6 foot cycle bar on it.
buck
05-08-2002 22:03:45
 Re: What a find in reply to premie-farmer, 05-08-2002 11:51:27
Overon page 2 on the implement bord ther is someone who just came cross a JD with tractor gearing and is apparently looking for a McCormick.Sounds like he may be able to tell you how to control it from the tractor seat.
Barnstormer
05-08-2002 18:50:16
I don't remember what model McCormick that we had but that was my first experience with a mower. Just remember, the guy sitting behind you is inhaling the fumes from a rear exhaust. My dad put a piece of flex pipe over the exhaust pipe and routed the exhaust down by the right wheel.
The other problem for a 10 year old (me) was the foot pressure on the pedal to raise the sickle bar. Talk about hurt! Was I abused? Nah-h-h.
Ray Oh
05-08-2002 16:15:26
It Will Work But Remember It Was Pulled By Horses So You Cant Fly Around The Field.Mowed With One When I Was A Kid.
John,PA
05-08-2002 13:32:56
I would suppose that any competent woodworker should be able to make you a new pitman arm. I would probably use OAK. :})
snitkawl
05-08-2002 15:28:58
 Re: Re: What a find in reply to John,PA, 05-08-2002 13:32:56
Your oak pittman would break pretty quick as oak is brash. Hickory is the wood of choice for pittman arms for the same reason it is the wood of choice for tool handles. It is tough.
John,PA
05-08-2002 16:20:56
 Re: Re: Re: What a find in reply to snitkawl, 05-08-2002 15:28:58
Yea, I agree. Trouble is I would have to order 300 bd. ft. as minimum purchase. Where-as, I have oak left from another job. :})
bg
05-08-2002 13:55:07
You can ususally buy replacement arms at TSC
JimmyJack
05-09-2002 07:20:01
 Re: Re: Re: What a find in reply to bg, 05-08-2002 13:55:07
Ive made several out of white oak and they worked fine.
