Front Mount Question
Rusty
05-08-2002 18:26:24
Just replaced the plate in a front mount distributor. Put the rotor and cap on. You can look through the hole where the coil goes and see the rotor. Should the copper on the rotor be lined up with the copper on the inside of the cap. How big should the gap be. No fire to the plugs and things do not seem to line up in the distributor.
Danny in CO
05-09-2002 07:47:47
 Re: Front Mount Question in reply to Rusty, 05-08-2002 18:26:24
I'm not quiet sure what you mean when you say copper on the rotor and copper on the cap. The rotor should have a metal (copper?) strip on top that MUST contact the metal (copper?) button in the middle of the cap inside. This is how the sparks get from the coil to each plug. If these don't contact and line up, something is wrong.
Here is a reply from ZANE in the past on a way to check out a front mount coil:
"Here is a way to check out a front mount coil and points etc. Not systematic or scientific but as the best mechanic I ever knew said, "The ignorant way" His name was Buch Nelson by the way and he worked all his adult life as a mechanic for the Talladega County Road Department. Retired and died a year later from cancer. (Too many days in the smoke and chemicals)If you have a can of starting fluid spray some into the air cleaner. If it starts you have problems with the fuel system. Probably some foreign matter in the bottom of the carb such as dirt or water. If it won't fire with starting fluid it is in the ignition and could be the points condenser etc. Remove wire to the coil from the resistor and check to see if you get a spark from the wire when you strike it to the frame of the tractor. If you do then remove the distributor cap and coil and take the distributor off the tractor by removing the two retaining bolts. When you put it back on be sure the offset on the shaft is in line with the offset on the cam gear. With the distributor off the tractor reconnect the coil wire and put the coil back on top of the distributor with the cap and wires off. Connect the base of the distributor to the tractor frame with one jumper cable. Using a cloths pin connect a wire from the base of the dist. to about 1/8" from the terminal that connects the distributor cap to the distributor. Turn the dist shaft and there should be a blue spark between the gap of the small jumper wire between the terminal and the base. If no spark you should turn the distributor till the points are open and then using an insulated handle screwdriver make contact between the two open point contacts. If it now fires you have a bad set of points and they are not making contact when they come together. They should be replaced. If you have no spark anywhere then you should try grounding the incoming spring connector from the coil at the bottom of the coil to the base of the distributor with the points removed from the distributor and also the condenser. If there is still not any spark from the coil you should replace the coil."
Hope this helps,
Danny
