Need help on governor rebuild.
Ric-Ky
05-09-2002 16:35:41
I am in the process of rebuilding the govenor on my '50 8N. Question: I bought a new Needle Bearing and Dust Seal. How Do I remove the Tapered Pin in the Fork so I can pull out the Lever shaft to replace the bearing and dust seal? I tried to drive it out with a small punch with no luck. Any ideas?
Also the Lever Assembly #18190 is very loose on the Governor body. Is there anyway to tighten it up a little?
Ed Gooding (VA)
05-09-2002 16:52:07
 Re: Need help on governor rebuild. in reply to Ric-Ky, 05-09-2002 16:35:41
Hey Ric. Forum member Don Stewart wrote a really nice tutorial on rebuilding the governor. You can view it by clicking here.
Hope this helps..... ..... Ed
'52 8N475798
Ric-Ky
05-09-2002 17:38:57
 Re: Re: Need help on governor rebuild. in reply to Ed Gooding (VA), 05-09-2002 16:52:07
Thanks Ed,
I have Don's rebuilding info. saved. I read it twice before I took the governor off. I just didn't cover removing the tappered pin in the governor fork. Thanks.
Gary (MO)
05-10-2002 04:17:31
 Re: Re: Re: Need help on governor rebuild. in reply to Ric-Ky, 05-09-2002 17:38:57
Per IT Shop Manual:
Sect 58: "... remove the TAPERED pin (Fig FO61) drom the govenor fork..."
Be sure you are punching the small end.
Rusty 2N
05-09-2002 16:41:00
I took the screwplug/oilline out of the back& used a drill bit for a punch. One tap & it came right out.
Ric-Ky
05-09-2002 16:43:59
 Re: Re: Need help on governor rebuild. in reply to Rusty 2N, 05-09-2002 16:41:00
Thank you Rusty 2N!!!
This is the best place for "N" formation
