Should I just Go it alone??
OKRon
05-09-2002 19:09:23
After disassembling my 2N for a much needed rebuild, I had the crankshaft turned and then saved up my $$ to buy the rebuild kit. After I finally bought the rebuild kit, I could not go any further for awhile because I planned to have a shop replace the sleeves and re-face the valve seats, and I needed to save up more money for that. Now, just as I have enough money to pay for that work, I have car trouble and the money is gonna be all used up. Should I just do this part myself?
With the video I purchased from the sponsors of this fine board, my I&T manual and lots of info from the archives, I think I can replace the sleeves myself. What about re-facing the valve seats? Can I get by with lapping the new valves to the seats? I do know someone who can measure the angle of the existing seats and tell me how far off from 45 degrees they are. I think I can come up with the $25-$50 to have the block and accessories dip-cleaned, but would I have a successful rebuild if I just scrubbed the engine down real good myself (and if so, what is the preferred cleaning solvent)?
Or is it worth the money to wait (possibly a few more months) to have a shop do the work I mentioned? I have planned all along to re-assemble everything myself after the shop is done.
Evil Steve
05-10-2002 08:22:00
 Re: Should I just Go it alone?? in reply to OKRon, 05-09-2002 19:09:23
OKRon-
A clean block is a very worthwhile investment. It can even help expose some other problems you may not otherwise see cleaning it yourself. Just be sure to clean out the oft-overlooked oil passage thru the block. Dipping alone won't get rid of blockage there.
If your valve seats aren't pitted too badly, why not lap the valves yourself? These are pretty tough engines built during a time when Ford actually expected people to perform their own repairs.
The sleeves are easier then you think, but you have to be patient and take it slowly so's you don't score a cylinder wall or bend one of your nice new sleeves.
You've gotten this far on your own and to do so tells me you can handle it fine without hiring someone else to complete it.
Best of luck.
John
05-09-2002 19:36:15
OKRon, grinding the valves yourself isn't so bad but, the sleeves are a different story. It's real easy to ruin a block if you mess this up. For the money I'd have some one do it with experence or at least have some one around who's done it before. Good luck John
John
05-09-2002 19:36:14
Craig MO
05-09-2002 19:35:55
I would take the work to the machine shop and do it right. You can put the sleeves in yourself if you freeze them and then have a plate to put them in square and even. Soap and water works best to clean even if shop does work it will get fine grit just blow dry with air after rinsing.
