Proofmeter Cable
How does it drive?
Arne - Idaho
05-13-2002 05:14:32
Hi Folks,
I finally got around to checking into my proofmeter to see why it doesn't work / if it can be fixed. When i took off the cable sheath I found no cable inside! Took off the meter and found it works if I spin a brass collar on the end where the cable attaches. I can't see how a cable would drive this though. I expected to see a square hole or something. Is this normal, and if not, how does it normally work?
Thanks,
Arne
bg
05-13-2002 05:40:42
 Re: Proofmeter Cable - How does it drive? in reply to Arne - Idaho, 05-13-2002 05:14:32
The square end of the cable fits inside the brass collar. The inside of the that driven part matches up to the cable end.
Arne
05-13-2002 06:51:22
 Re: Re: Proofmeter Cable - How does it drive? in reply to bg, 05-13-2002 05:40:42
Thanks BG,
That may be the root of the problem, the meter end didn't look as if it had a square hole. I guess I will order a cable anyway and see if I can fix it.
Arne
bg
05-13-2002 08:02:07
 Re: Re: Re: Proofmeter Cable - How does it drive? in reply to Arne, 05-13-2002 06:51:22
You can't see the square part inside there. But if you take a piece of square keystock the right size, you can insert it and tell if it's still square inside.
Arne
05-13-2002 08:24:36
 Re: Re: Re: Re: Proofmeter Cable - How does it drive? in reply to bg, 05-13-2002 08:02:07
I just ordered a new cable. I hope this fixes it. :-) Thanks for the replies bg.
Arne
