Order Ford 8N Parts Online
PVC SET UP FOR 8n
1951 8n Greg/Mo
05-14-2002 19:49:48
Has anyone thought about tapping in to your intake manifold and running a tube to the oil filler neck to try and stop the moisture build up????? Any ideas??? 1951 8n Greg Montana
Frank Fox
05-15-2002 21:50:53
 Re: PVC SET UP FOR 8n in reply to 1951 8n Greg/Montana, 05-14-2002 19:49:48
Greg I put a PCV on my 8N and have operated it for over 40 hours mowing and discing. It runs fine and I have eliminated the formation of water vapor in the oil filler tube. The oil stays cleaner, fourty plus hours and still clear. By the way I use 20/50 Chevron oil. Oil pressure is 18psi when hot (after two hours of discing) and 40psi when cold. I also used "PVC" insted of PCV when I posted my idea on the forum and was justly corrected. Contact me by E-mail and I will give you the details and a list of the parts I used. Frank foxaero@aol.com
Al English
05-15-2002 05:04:43
Hi Greg,
Since everyone understood your question this is a minor point. But what you are referring to is PCV(Positive Crankcase Ventilation), not PVC which is the acronym for a type of plastic(PolyVinylChloride)...Al English
Rob
05-15-2002 04:32:37
I put a new breather cap on there and the moisture problem disappeared.
DaveSmith
05-15-2002 04:32:21
The N powered Govt surplus generator I bought has a collar fastened to the rear valve cover with a baffle inside. A flex tube goes to the air cleaner tube which has a collar brazed to it. No PVC valve in the line. It was done at the factory. This engine is goverened to run at 1800 RPM steady.
Dave <*)))><
Barnstormer
05-15-2002 04:03:56
Do you have a thermostat in your tractor? Sounds like the engine is not getting up to working temperature.
John
05-15-2002 03:46:52
Greg, do you really want to burn all that milky oil in your motor? There wouldn't be no tapping if your manifolds an oringinal, theres a pipe plug in it where they ran vaccum for milkers. This doesn't sound like a good idea to me, and I don't think it would help I've seen that build up on a lot of motors with pvc hooked up.
