Starter problem
Richard(WY)
05-15-2002 07:47:13
I put new brushes and bushings in my starter. The shaft turns freely. When current is applied the starter will not spin. There is strong resistance if you try to turn it backwards. What did I do? Thanks.
I am ashamed to admit that I am a card carrying member of the IBEW and electrically challenged!
check for a ground in the field==bj/8n/mt==ntxt
05-15-2002 10:27:16
 Re: Starter problem in reply to Richard(WY), 05-15-2002 07:47:13
ntxt
Evil Steve
05-15-2002 08:03:32
When you rebuilt the starter did you only put in the brushes and bushings? You also need to turn the stator so that the mica is not sticking out (even undercut it .005" is better). New brushes will not "contour" as well as the old ones so between these two possible problems, your brushes simply aren't making good enough contact. If you have done this, you may have an arcing problem.
