621 Position/Draft control
Albert J. Brune
11-18-2000 14:14:53
I now have the 621 running quite well. I've shredded quite a bit with it and tried bladding with it on Thursday. when trying to move some of the brush and cactus I've shredded , the blade doed not scrape too well. It tends to lift when something is hard to move close to the ground. I did have it in position control. What should I be doing to scrape the ground to "bare" earth? Thanks albe
albe
11-19-2000 08:34:40
 Re: 621 Position/Draft control in reply to Albert J. Brunett, 11-18-2000 14:14:53
Thanks for all the help. I don't have an old crank lying about but I have other weight. I can also tip the blade with the top link. I'll try this week-end
Ed Gooding (VA)
11-19-2000 04:01:47
Hi Albert. I had an ole truck crankshaft laying around and strapped it to the top of my 6' blade. Doesn't look too pretty, but the blade didn't either.....grin. The extra weight helps it get a better "bite".
Hope this helps..... ..... Ed
'52 8N475798
Carl/Pa
11-18-2000 16:47:07
If you are using a rear blade you can shorten the top link and tip the blade. This may help.
2fordsmike
11-19-2000 12:16:14
 Re: Re: 621 Position/Draft control in reply to Carl/Pa, 11-18-2000 16:47:07
I LENGTHEN the top link to give my 3-point blade a better bite. Mike-Iowa
ZANE
11-18-2000 14:52:30
The Ford tractor has no down pressure. If you want it to have more force against the ground you will have to weight it down with something.
Even is position control it is supposed to go up with the terrain. If it didn't you would not be able to use the tractor for blading because the rear wheels would be off the ground half of the time. IH did build a few modles with down pressure and they were not sucessful at all.
