Order Ford 8N Parts Online
Can't get my 8N to start
Ray Gremillion
05-17-2002 16:43:23
My 1952 8N began to run rough. Then it quit running altogether. The carburetor was worn out so, we changed it. Still would'nt start. We changed the spark plugs. We held a screwdriver from the plug wire to chassis and got good fire. I cannot see any wet on the plugs so, I can't tell if I'm getting fuel. Please give me some advice on what to check next. Ray
Greg (NV)
05-17-2002 17:02:39
 Re: Can't get my 8N to start in reply to Ray Gremillion, 05-17-2002 16:43:23
Ray, have you checked to see if you've got gas in the tank? Not trying to be a smart-a$$ but I ran the battery down on my 52 one day until I discovered it was out of gas. Dumb me! Can you see gas in the sediment bowl? Have you checked the filter in the carb? If you're getting a good hot spark I would say it would be fuel related. I'm sure others will write with more things to check.
Greg
Nevada
Ray Gremillion
05-17-2002 17:18:13
 Re: Re: Can't get my 8N to start in reply to Greg (NV), 05-17-2002 17:02:39
Yep, got gas in bowl and, could see it gurgling in bowl from tank when we first tried to fire it up. Thanks for such a quick response to my post.
Ray
Dan
05-17-2002 17:43:39
 Re: Re: Re: Can't get my 8N to start in reply to Ray Gremillion, 05-17-2002 17:18:13
So you have gas to the carb . But is the gas getting from the carb bowl ,through the main needle yalve --through the main jet(that little pipe that pokes up ) to the venturi ? This can plug up and shuy the whole thing down .
ALBERT ROSAMILIA
06-29-2004 08:07:50
 Re: Re: Re: Re: Can't get my 8N to start in reply to Dan, 05-17-2002 17:43:39
MY 9N FORD TRACTOR IS HARD TO START IT CRANKES A LONG TIME BEFORE IT STARTS MYBE SOME TIMES THE BATTERY WILL GO DEAD TRYING AND I HAVE TO TRY AGAIN BEFORE IT STARTS IT SEEMS TO TRY TO STAR FOR A LONG TIME THEN IT WILL START AFTER IT WOMES UP IT MIGHT START QUICKER
ALBERT ROSAMILIA
06-29-2004 08:06:44
Ray Gremillion
05-17-2002 19:13:15
OK the plugs are wet. What kind of timing set-up do we have on this machine? Is there a timing chain? Gear? Where is it? Is there something I should know before I tear into it? Or what else could it be if not timing? Got fire, got gas and looks like I have compression. Ray
Dell (WA)
05-17-2002 22:08:57
 Re: Re: Re: Re: Re: Can't get my 8N to start in reply to Ray Gremillion, 05-17-2002 19:13:15
Ray..... ...your sidemount 8N has timing port on tranny housing under great big humongus screwhead just infront of your right toe. Timing is 4 deg BTDC at idle 450 rpms..... .Dell
