Order Ford 8N Parts Online
8n hyd lift
Robert
05-18-2002 20:16:13
I was using a boom pole to move some cedar logs and noticed that when I had the lift all the way up with the load, the lift would not go down when I lowered it. I had the lift in the down pos. and went and let the log down with the come-a-long I was using to balance the log the lift let down when the weight was let off. I tried several times moving the position control up and down withno luck letting down with a load hooked up. Can anyone help me here
Thanks Robert
By the way I just rebuilt the Hyd. pump and Cylinder and I used the naa piston.
Rob
05-19-2002 03:19:10
 Re: 8n hyd lift in reply to Robert, 05-18-2002 20:16:13
Exhaust control valve sticking? Control linkage broken or binding?
