Important question?
Ron Ca.
05-19-2002 16:19:36
My wife lay the law down. No more fun with my 9-N, untill I fix her 1988 olds ciera. Which stalls at stop signs. Already replaced the fuel pump. Thanks for any and all suggestions.
Jhill
05-20-2002 07:08:06
 Re: Important question? in reply to Ron Ca., 05-19-2002 16:19:36
If gasket below doesn't work look at the idle air control valve. They get gummed up at about 100,000 miles and cause stalling at stops.
Tom 8N396936
05-20-2002 04:56:05
Just tell her not to stop and go back to your N ;>)
OKRon
05-19-2002 20:31:56
Ron, I had the same problem with my '92 Olds Cierra. In my case, the car would stall and would not start again for about 20 minutes. This only happened if I had been driving for more than half an hour. Turns out it was the computer. $400+. Also, the check engine light was on most of the time while I was driving. I hope you find it to be something cheaper.
Richard(WY)
05-19-2002 20:18:23
this is a no brainer. replace the throttle body gasket, a big thick sucker. You should be good to go for another 100000 miles.
PCC-AL
05-19-2002 19:10:34
Hi Ron,
Don't know if this has anything to do with your problems, but hope it helps.
I had a 1987 Olds, Delta 88, V-6. Driving at 70 on the Interstate, it would just go dead. No brakes, steering or anything. Scary. Finally traced the problem down to the air-flow sensor. Lots of mechanics and repair shops later, I just traded the car at a loss. It was dangerous. Hope yours isn't that bad. Good luck.
Ron Ca.
05-19-2002 16:58:42
Thanks for quick responce! Affirmative on the T.B.I.
PsRumors
05-19-2002 16:24:10
Is it throttle body injected?
