Order Ford 8N Parts Online
8n lift operation
Robert
05-19-2002 20:35:08
I was using a boom pole to move some cedar logs and noticed that when I had the lift all the way up with the load, the lift would not go down when I lowered it. I had the lift in the down pos. and went and let the log down with the come-a-long I was using to balance the log the lift let down when the weight was let off. I tried several times moving the position control up and down withno luck letting down with a load hooked up. Can anyone help me here Thanks Robert
By the way I just rebuilt the Hyd. pump and Cylinder and I used the naa piston.
