Order Ford 8N Parts Online
8n lift operation question
Robert
05-20-2002 20:30:04
Ford 9N, 2N & 8N Discussion Board Click Here for 8N, 9N, 2N Parts Click Here for 8N, 9N, 2N Manuals
8n lift operation
Posted by Robert on May 19, 2002 at 20:35:08 from (152.163.201.84):
I was using a boom pole to move some cedar logs and noticed that when I had the lift all the way up with the load, the lift would not go down when I lowered it. I had the lift in the down pos. and went and let the log down with the come-a-long I was using to balance the log the lift let down when the weight was let off. I tried several times moving the position control up and down withno luck letting down with a load hooked up. Can anyone help me here Thanks Robert
By the way I just rebuilt the Hyd. pump and Cylinder and I used the naa piston.
listen to Zane==bj/8n/mt
05-21-2002 05:53:54
 Re: 8n lift operation question in reply to Robert, 05-20-2002 20:30:04
If Zane says plant oats on the barn roof go borrow a ladder.
There is a reason for those decals that come with the set that say not to pull from above the axle center line.
Your mileage may vary
ZANE
05-21-2002 05:04:26
Not trying to be a smartie but you should not be trying to move logs with a boom pole to begin with. That is a very dangerous thing to do. A log should be towed as close to the back of the tractor as possible to prevent the tractor rearing up in the front and possibly overturning. The boom pole is too far back to be lifting more than a couple of hundred pounds and when the log bounces or hangs it is putting tremendous loads on the hydraulics.
The control valve is sticking. This is caused from overloading and possibly either or a scored control valve spool and bushing and or a weak return spring in the control valve.
Fast Ed Ohio
05-20-2002 22:40:16
Just a guess , that long lever that goes from the top of the lift cover down into the sump came out of that little hole it sets in ( uneven heavy weight could cause this ) 8N ? , sound like your gonna have to pop the top and have a look see .
