Thanks for all the good advice folks. Answers to questions. BOB: I'M CERTAINLY NOT THAT MUCH OF A HILLBILLY THAT I'M GOING TO CRAWL UNDER THE THING WITH IT RUNNING. BUT THANKS FOR THE WORDS OF CAUTION! Evil Steve: It's an 8N, Yes I have ORC (put on by previous owner prior to sell :) I've had the tractor about a month), I really can't remember if the mower was running in neutral prior to shut down or not this is the first time I've needed to lift anything in neutral (with the ORC it spins a long time anyhow) I'll have to check into that after I get the tire fixed tomorrow. However, thanks I did forget the simple thing of checking the fluid so I'll do that first when I have the tire back on and am level. Must it be checked engine running and warm or does it matter? Dell: Yes I do, but I am learning something new every time I use the thing. Thanks for the advice I'll repost when I get the tire fixed and can dig into this a little more. I thought it should lift in neutral but wasn't sure since it works off the tranny's PTO. I wasn't sure if it was geared to work in neutral orginally or if something was broke. No use trying to fix something if it wasn't designed to do it in the first place.
