2N loader?
Andrew
05-23-2002 12:02:01
I have a 1946 2n that I would like to get a loader for but I don't how much I should pay for one. Do any of you have a certain type that you realy like or would recomend. Also can any one tell me what other things I would need to run one, like a pump or anything (also price range). And where are these things mounted. What kind of controler do they have. Any other information would also be great. Thanks!
scott upny
05-24-2002 06:19:25
 Re: 2N loader? in reply to Andrew , 05-23-2002 12:02:01
I've got a wagner loader off my 8N for sale. The only thing you'll need is the crank pulley and shaft. E-mail me if you're interested.
ED-IL
05-23-2002 14:30:23
Have you considered a brand new paulson loader?
third party image
as was stated previously, you might also consider Zane's Live Thang to supply the hydraulics. Your other options are running it from the PTO pump, but that means you can't use the three point hitch, or mount a pump forward of the engine, and that will make it hard to change the fan belt.
Ron/Pa
05-23-2002 12:42:19
Just a few random thoughts, you will need a pump or a Live thang, (if that will run it) check with Zane. You need to consider the fact that you have no power steering, and the loader alone adds alot of weight to the steering. Be sure that you are confident in the condition of your engine, and ignition. Once the loader is on and lowered, it is a real bear to get to the engine. This is not to try to talk you out of a loader, just a few thoughts, from been there, done that. Good luck
Ron
