Bog harrow
Peter Button
05-24-2002 04:34:44
What size bog harrow can I pull behind my 44 2n? Have been clearing a field for the past four years and it's almost ready. TIA
Ed Gooding (VA)
05-27-2002 04:06:41
 Re: bog harrow in reply to Peter Button, 05-24-2002 04:34:44
Hi Peter. Here's the description page from the Dearborn Bush & Bog Harrow owner's manual. You can definitely pull one with your 2N.
third party image
Hope this helps..... ..... Ed
'52 8N475798
Phil (VA)
05-24-2002 09:25:42
If I remember correctly, the Dearborn Bog Harrow was made for those tractors and should pull easily. It is either 5 ft or 6 ft and it only has one row of blades. Your tractor actually will pull a 5 ft. double row harrow no problem, but you specifically asked about the bog harrow.
HIPOCKETS
05-27-2002 21:26:05
 Re: Re: bog harrow in reply to Phil (VA), 05-24-2002 09:25:42
Hi Peter.. I have a 41 9n, purchased a 6 ft. disk from tractor supply sales. Disk has the bog harrow disk in front and the regular disk in the rear. No problems pulling it. Have tried all the different angle setting, does a great job around trees and brush areas.
