Update to last nights enjoyment put to an end
Premie-farmer
05-25-2002 18:02:35
I like to post back when I figure a problem out maybe it will help some body else. I found out why the hydraulics wouldn't work in neutral. Took Evil Steve's advice and D/C mower from PTO. replaced the flat tire. Fired the 8N up touched the lift lever and up the mower came. Seams whent the right front tire blew the mower blade dug into the ground and I guess the PTO couldn't pull the blade around and run the hydraulics at the same time in neutral. Anyway it's working now fluid is fine and the lift goes all the way up with out a problem in all gears. Thanks
