ORC is broke and I can't get it off!
Tom A
05-28-2002 04:34:27
Hey all,
my ORC locked up the other day, just won't freewheel anymore.
When I tried to remove it from the PTO shaft, I discovered that I couldn't access the spring pin that holds it on--the holes won't line up because the ORC is locked in one position. When I turn the ORC by hand, the whole PTO shaft turns too, so I can not get the holes to line up.
Any suggestions (hopefully easy ones)?
thanks,
tom
OKFarmer
05-28-2002 07:04:28
 Re: ORC is broke and I can't get it off! in reply to Tom A, 05-28-2002 04:34:27
Two Words.....FIRE WRENCH. Carefully shave that ORC off. Some people make mistake of cutting directly toward the tractor (cut a groove). What you need to do is shave it on one side til your down to the pto shaft. It's simple!
Salmoneye
05-28-2002 04:43:49
Engage the PTO with the engine off and that will lock the shaft.
Try and turn the outside of the broken ORC with a pipe wrench till the holes line up...
Salmoneye...PS...
05-28-2002 04:56:17
 Re: Re: ORC is broke and I can't get it off! in reply to Salmoneye, 05-28-2002 04:43:49
If that does not work, you will have to pull the shaft and get a better bite on that sucker I think...
TimK
05-28-2002 06:24:14
 Re: Re: Re: ORC is broke and I can't get it off! in reply to Salmoneye...PS..., 05-28-2002 04:56:17
I'm for pulling that PTO shaft out and working on it while the shaft is clamped in a vise. My ORC has a spring clip on the outside that holds the drum in place ( that's the part that won't turn for you ). I think if I had that PTO out and clamped in a vise, I could break the spring clip off and drive the drum off with a hammer. My $.02
