Dearborn loader
ROGER
05-28-2002 12:50:58
THE LOADER ON MY 8N WAS WORKING GREAT UNTILL THE FRONT SEAL BLEW ON THE FRONT MOUNT HYDRAULIC PUMP.ITS THE OLD STYLE AND DONT KNOW IF REBUILD KITS ARE AVALIABLE OR NOT? ANY HELP ON REBUILDING PUMP WOULD BE APPRECIATED.ARE THERE ANY OTHER FRONT MOUNTED PUMPS THAT WOULD WORK ON DEARBORN LOADER MODEL 19-22? THANKS IN ADVANCE. ROGER
John
05-28-2002 20:45:25
 Re: dearborn loader in reply to ROGER, 05-28-2002 12:50:58
Roger, Thats probably an old vein type pump. I don't know where you can get seals at, or if you can. Try your local machine shop or a place that works with hydralics. If they can getit or at least cross reference it for you. And if that fails you should be able to adapt a pump to your loader as long as you can hook to your pump drive. You may have to build a new bracket, that pumpbolts vertically and a lot of them now bolt horizonally. Good luck John
