2n Hydraulic problems
Ross inNH
05-28-2002 15:41:40
I just brought home a 2n that runs very well but the hydraulics are not well. When lifting a heavy load there is a fair amount of noise coming from the pump also the lift will remain in the up position after lifting up a heavy impliment. the lever can be put in the down position with no results. It will come down very slowly over a period of about 15 min. or so. The oil that is in there is 90 weight which I will replace. Thanks in advance for the advice. Ross
Brian-2N
05-29-2002 06:23:45
 Re: 2n Hydraulic problems in reply to Ross inNH, 05-28-2002 15:41:40
Ross,
Start with the simple-replace the fluid. Could be crummy. You might want to check for leaks. Remove the side plates and operate the lift. If you see fluid spraying, something is cracked and leaking. If there are no leaks, it could just be very dirty. If you are interested, I have the J&D Productions tape on hydraulic repair. Give me a jingle and I can drop it off.
Scott
05-28-2002 15:53:12
The control valve (has T handle that fits into fork coming down from the top) is sticking in the pump either from old oil or mixing 2 different oils together (lets hope not) will keep the lift arms from dropping.
