Plowed
River
05-30-2002 17:57:19
I need to construct and build a front blade for my 8n. I do have a striped down blade and need pictures to make the undercarriage and lifting apparatus. Thanks
River (MI)
06-03-2002 16:27:53
 Re: plowed in reply to River, 05-30-2002 17:57:19
Thanks for all the help.Got some real good idias.
SteveB(wi)
05-31-2002 13:45:01
Some one last fall had constructed and posted pics of a really clean installation of a Meyers hydro turn plow on their machine but I can't remember who it was. You would also need 12V for that.
Ultradog MN
05-31-2002 04:07:06
Follow the link below to some pictures of a snow plow I built last fall.
Feel free to email me for more info.
It's fun building stuff for your tractor.
Been thinking I might like to build a road grader for my 2N next. I don't need a road grader but I sure would like to build one.
Good luck
Ed Gooding (VA)
05-31-2002 04:58:16
 Re: Re: plowed in reply to Ultradog MN, 05-31-2002 04:07:06
Here's a scan of an ad brochure for the Arps Universal Frame. A lot different from the Dearborn version, and allowed you to have a belly grader blade and front dozer blade on at the same time.
third party image
Hope this helps..... ..... Ed
'52 8N475798
Tom-Pa
05-31-2002 07:46:34
 Re: Re: Re: plowed in reply to Ed Gooding (VA), 05-31-2002 04:58:16
I have the Blackhawk frame as shown for my snowplow setup. But, without the grader blade. It is a blackhawk snowplow by Arps, Corp.
TOm-Pa
Ultradog MN
05-31-2002 05:35:17
Thanks Ed.
I'd never seen the grader before.
Tell you what I'd like to build:
Get another front axle and wheels, radius rods, etc from an N
and install it on a frame that makes your tractor about 8+? ft. longer. You drive the front wheels of your own tractor onto it. Hook the back end of the grader frame onto the lift arms. CLAMP the front wheels from your tractor into pivoting rests that would steer the new front axle. You'd be driving uphill all the time but the weight of the front end of your tractor would give you some pretty good ground engagement.
The blade would be fixed to the grader frame. You'd adjust the height with your lifting arms. You could grade a crown in the road by adjusting the leveling crank?? 2 pins and unclamp the wheels and drive back off.
I've got it in my head but don't know if it makes any sense when I try to describe it.
Ed Gooding (VA)
05-31-2002 05:53:17
 Re: Re: Re: Re: plowed in reply to Ultradog MN, 05-31-2002 05:35:17
Hmmmm, in other words, something more like this?
third party image
third party image
Regards..... ..... Ed
'52 8N475798
Ed Gooding (VA)
05-31-2002 05:08:58
Thought it might be helpful to show what it looks like on the tractor:
third party image
Good luck with it..... ..Ed
'52 8N475798
Ultradog MN
05-31-2002 05:39:22
 Re: Re: Re: Re: plowed in reply to Ed Gooding (VA), 05-31-2002 05:08:58
I've seen a unit like yours for a Cub but they used the same blade for both front and underneath.
Just switch it back and forth.
Ed Gooding (VA)
05-31-2002 03:34:17
Here is a parts explosion of the Dearborn, model 19-1 Universal Frame, to which you could attach a snow plow or dozer blade.
third party image
'52 8N475798
