Order Ford 8N Parts Online
Dearborn Loader on Ford 8N
Phil G.
06-03-2002 04:32:10
Does anyone have an owners manual for a Dearborn Loader Model # 19-31? I have one mounted on an 8N Ford. I need to know what type of hydraulic fluid and what the capacity of the system is.I have the front mounted pump.There is no breather in the system,is this correct?Doesn't seem logical.I would gladly pay for a reprint or a copy of the manual.Any help will be greatly appreciated.Thanks in advance.
Dell (WA)
06-03-2002 09:12:56
 Re: Dearborn Loader on Ford 8N in reply to Phil G., 06-03-2002 04:32:10
Phil..... ..for a manual, check with www.n-news.com archives of manuals..... ...Dell
Ed Gooding (VA)
06-03-2002 05:58:23
Hi Phil. Model 19-31 was assigned to a bucket that was typically used on a Model 19-22 Dearborn loader. If you go to the link that Dave posted, check out the user's manual for the 19-22 loader and see if that's what you have. I have the master parts book for this, as well as the owner's manual at the link that Dave gave you. It should answer your question about the oil. If memory serves (highly suspect these days), it should take about 4 ½ gallons of the same oil you use in the engine of your 8N.
Here's an ad for the 19-22 for you to compare to your loader:
third party image
Hope this helps..... ..... Ed
'52 8N475798
Dick H
06-03-2002 08:24:33
 Re: Re: Dearborn Loader on Ford 8N in reply to Ed Gooding (VA), 06-03-2002 05:58:23
Good question about the hydraulic fluid (type).
I read in the archives that one should not use the same hydraulic fluid as in the tractor. An external pump requires a mineral based oil. To use the 134 Fluid is not good, due to the additives in the fluid.
Any comments about that?
Thanks,
Dick H.
Ed Gooding (VA)
06-03-2002 09:39:03
 Re: Re: Re: Dearborn Loader on Ford 8N in reply to Dick H, 06-03-2002 08:24:33
Hi Dick.
>> I read in the archives that one should not use the same hydraulic fluid as in the tractor. <<
You use the same weight SAE oil as used in the tractor's engine, not the same as used in the tractor's hydraulics.
Hope this helps..... ..... .Ed
'52 8N475798
