Sherman under only tranny value
OldeightNer
11-20-2000 21:32:41
Hello all, OldeightNer here again with more dumb questions.I recently found an under only Sherman transmission in a junk yard on a 9N Ford.Will it fit on my 8N? Also can anyone tell me the approxiate value for one in great condition,as this one seems to be? Thanks for all your help, OldeightNer
Dell (WA)
11-21-2000 01:53:32
 Re: Sherman under only tranny value in reply to OldeightNer, 11-20-2000 21:32:41
Somewhere in the early 9N's production run, they changed the tranny input gear from straight cut to hylical cut (on an angle). The 8N's tranny input shaft is also hylical cut. I believe that they are interchangeable but I am not an expert on that.
If your sherman under comes with the "correct" input shaft gear, you just might be lucky.
Shermans are worth more out of a tractor that in the tractor for some reason. I can not give you a real "value" but 3-speed shermans are being asked for $600 to 800 on E-bay. I've saved an awfull lot of money at auctions by being 2nd highest bidder..... ...Dell
