How To Balance Bush Hog Blades?
Arthur Brestlin
06-04-2002 15:58:17
Does anyone have plans to make a balance scale on which to equalize the weight of Rotary Cutter Blades? I just sharpened the blades on my Ford 951B Rotary Cutter which came with my '51 8N. I thought I "took off" an equal amount on each blade, but when I used it this weekend, my fenders were almost airborne with the vibration. As always, any suggestions greatly appreciated!
Arne
06-05-2002 07:06:45
 Re: How To Balance Bush Hog Blades? in reply to Arthur Brestlin, 06-04-2002 15:58:17
Could you have gotten your pto driveline out of phase? If you took the shaft apart, make sure it isn't 90 degrees off. It will cause bad vibration.
Arne
Randall(AL)
06-05-2002 07:00:56
Since bushhog blades are each on opposing sides of the stumpjumper the individual blade would not need to be balanced like you do a lawn mower blade. If you think it will help to balance them (which I have never heard of any one doing and doubt it will help anything) go to your local fishing store or Walmart and buy a balance beam like fisherman use to see which fish is bigger. Put a blade on each end whichever blade is heavier start taking material off the other till the blades are of equal weight. When both blades are of equal weight they should be balanced. That is if the bolts nuts and lockwashers all weigh the same. Hope this helps..
Randall(AL) Part II
06-05-2002 08:54:45
 Re: Re: How To Balance Bush Hog Blades? in reply to Randall(AL), 06-05-2002 07:00:56
I re-read this post and my wording sounds as if I'm telling you to regrind the lighter blade. What I actually meant was to grind some more material off the heavier blade.
Ken in PA
06-04-2002 20:29:52
Ok here is my solution to the problem.
Get from somewhere a spacer that will fit snugly in the blade holes and not quite as thick as the two blades stacked. Whatever you get needs to have a hole in the center you can feed some all thread through and put a large washer on each side that is bigger than the blade hole. Lay the blades on edge on a flat work bench with the holes lined up and one blade pointing to the right and the other pointing to the left. Assemble the wizz bang widget hickey that I clearly described above and tighten the nuts on the all thread nice and snug. I think in this case a picture would be worth a million words but what you aend up with should look like a lawn mower blade with a hunk of all thread somehow perfectly centered in the arbor hole with a few inches of thread sticking out each side.
I this seems confusing I more than understand. I am starting to loose track myself but anyhow, now you can place the all thread stubs on the smoothe and very level jaws of a vice that is left open a bit and the heavy blade will fall. Grind away at that side untill it will balance.
Lots of room for improvement in the above but you just bolt the blades to one another to look like a mower blade in any way you can to make sure the all thread is centered and let the law of gravity do the rest.
Good luck,
Ken
Jerry (AL)
06-04-2002 18:57:15
Saw a real neat way to balance a turning object several years back. It consisted of a flat metal circular plate with a plastic tube welded around the outer edge. The tube was filled with a liquid (hydraukic oil) and several ball bearings. The bearings would rotate around to balance the whole shaft. Can't figure out how to do it on a bush hog though.
Saw a demonstration where wheel weights were moved about on a trailer tire and then rotated at different rpm's. The bearings would slide around dependent on the rpm's and the axle, tire, and rim were always in balance.
This rig was a development of the racer, Bobby Allison. At one time, a lot of police and trooper cars had them.
Upper Peninsula, Mi.
06-04-2002 18:54:57
HiArt. I weigh the blades on my wife's food scale. It is accurate within one ounce, so does the job. Have sharpened the blades many times and no problem yet. Ron
AB
06-04-2002 17:51:54
Hay Art shot in the dark here but is it possible that one of the blades is binding on it's bolt? I had a shaker once as you describe and cured it by cleaning and greasing the sholder bolts so that the blades spin free. If they can't straighten out under there while spinning it won't balance even if the blades weigh the same. HTH..... ..AB
Arthur Brestlin
06-05-2002 03:44:46
 Re: Re: How To Balance Bush Hog Blades? in reply to AB, 06-04-2002 17:51:54
Thanks for the thought AB. As I recall, when I removed the blades they were not able to turn on the the bolts. I wire brushed them before assembly, but did not use any lube. I did'nt see lube suggested in the owners manual, but if they are supposed to turn freely, grease can't hurt. I will try it this weekend. Thanks for the idea!
Arthur
Ken
06-04-2002 16:15:41
I always just stick a screw driver in the center hole on the blade and hold it extended out. When the blade is balanced and not tipped to one side it is level. If it is tipped to one side use the grinder and take a little off the side that tips. Not real professional but it works good.
EDDIE8N
06-04-2002 16:50:00
 Re: Re: How To Balance Bush Hog Blades? in reply to Ken, 06-04-2002 16:15:41
KEN,
I can see how that method works for blades for a finish mower,(I do it the same way for lawn mower blades).
But ,I can't see how it would work for a brushhog blade that has a cutting edge on one end and a pivot hole on the other end...or am I missing something here?
EDDIE8N
RWK in WI
06-05-2002 05:32:41
 Re: Re: Re: How To Balance Bush Hog Blades? in reply to EDDIE8N, 06-04-2002 16:50:00
When I could get the blades off the brush hog I took a wire coat hanger bent the center up and used 2 Shooks to hang a hog blade on each end. when coat hanger stayed level the baldes were close enough to balanced.
Hope this helps you.
