Reverse direction fan
Richard Miller
06-04-2002 20:09:40
Has anyone run across a reverse direction rad fan.
I have a 9n that would that would melt out the coil in a very short time if worked hard in very hot weather. Always did ok on light work or in cooler weather. I discovered the cooling fan pushed air forward through the rad thus pulling all the engine heat through the coil.I put on another fan blade and have had no trouble since.
There had to be a reason for a reverse fan. Was this a ford item for some application or something aftermarket.JUST CURIOUS. Thanks.
RPMO
Ed Gooding (VA)
06-05-2002 02:21:09
 Re: Reverse direction fan in reply to Richard Miller, 06-04-2002 20:09:40
Hi Richard. Mark and Fast Ed answered your question, but I thought I'd augment the answers with an original ad from an accessory catalog from the N-days:
third party image
Hope this helps..... ..... Ed
'52 8N475798
Mark Hendershot
06-04-2002 20:28:37
I have one on my 9N kind of nice now that it is summer and it dose not blow the heat on you. In the winter I like it the other way. Can't win for losing. It was a option for them. Mark H.
Fast Ed Ohio
06-04-2002 21:20:13
 Re: Re: Reverse direction fan in reply to Mark Hendershot, 06-04-2002 20:28:37
If your running through high weeds it helps keep the radiator clear so it wont overheat, had a neighbor years ago overheated his N plowing an overgrown pasture, had to have the engine rebuilt.I didnt do the rebuild I think I was about 10 or 12 at the time . ( 1955 ? )
