Been thinking about magneto's
9N'er
06-05-2002 16:05:18
Been thinking that the electric ignition system, key switches, resistors in series, all that stuff is really complicated. I mean, how simple could it be...just run the starter from the batter and that's it. Let a magneto do it's own thing...and fire away those sparkies to the plugs.
Yep, during the war, the 2N's lost their battery starts and ignition systems and 2N's had to have magnetos for the war effort. But in all reality, aren't they a simpler system to maintain and use?
Just curious why the magneto was replaced again with the battery ignition system?? After working with this Farmall A and magneto it certainly seems simple. Problem with the battery? it just fires up the starter motor...well oh well, crank it and let the magneto fire up the old motor.
What do you think?
Ken in PA
06-05-2002 21:34:49
 Re: been thinking about magneto's in reply to 9N'er, 06-05-2002 16:05:18
They used them in alot of race cars for years because they were real hot and reliable. Now they use the distributors because the technology is so much better as far as adjustable timing advance and rev-limiters and such. Some spark boxes even have spark retard for use with turbos or blowers.
Real good technology but they always have two of everything and a dash switch to trigger the back up unit if the first one dies..... Makes you think doesn't it?
Ken
bg
06-05-2002 16:29:32
Lawnmowers use magnetos. They always seem to start. I guess if you don't need lights or battery start, a magneto would be fine.
