2n tractor carb settings
Rick R.
06-07-2002 15:13:09
I need to know the initial number of turns on the carb mixture needles to get it started so I can then adjust it to run smooth. I can't seem to find it in my manual. Sure would appreciate some help.
try . . . Dell (WA)
06-07-2002 18:45:45
 Re: 2n tractor carb settings in reply to Rick R., 06-07-2002 15:13:09
Rick..... ....my Ford Owners manual sez 1 turn out for both idle mixture and main jet. That would probably be good for new engine and new carb.
I usually set the idle mixture to 1 1/2 turns and usually set and leave the main jet at 2 turns. (I'll check plug color for soot after doing some real tractor work like brushoggin') But generally, I'd rather run a little rich and not burn a valve. With no-lead gas, even reading plugs is not a sure thing.
Idle mixture is maximized at 450 rpms idle speed. If it don't start eazy, enrich 1/8 turn..... ..Dell
