Order Ford 8N Parts Online
8N grading in reverse
Sam at Classic
06-08-2002 12:35:30
Been reading this forum for about over a year. I was wondering if anyone else has had this problem. I was using a landscape rake to move loose fill dirt. I had the rake rotated to push to the rear. When the tractor would go uphill, usually 35 to 45 degrees, it would stall out. Is this common? I even tried going back with no load, and it would still stall out. Is it because of gravity feed? Any help would be appreciated.
Bob in NY
06-08-2002 13:15:27
 Re: 8N grading in reverse in reply to Sam at Classic Manor, 06-08-2002 12:35:30
Did you try going uphill forward? You might be right about the gravity feed. The pickup tube in the tank is about an inch & 1/2 long, and if the tank wasn't full, you might not have any fuel to pickup at a steep angle. Bob in NY
Fast Ed Ohio
06-08-2002 22:32:38
 Re: Re: 8N grading in reverse in reply to Bob in NY, 06-08-2002 13:15:27
Sound like a carb. float problem.( Bend the float up just a hair ,not to much or it will start flooding on you.
Rusty 2N
06-08-2002 17:00:41
Bob I'd take that one satep further & drain the tank & pull the flow valve & check the screen in there. If it's dirty then even less of an angle will shut you down. Just a thought. Good luck Sam.
Sam at classic manor
06-08-2002 18:42:09
 Re: Re: Re: 8N grading in reverse in reply to Rusty 2N, 06-08-2002 17:00:41
Sorry I didn't get back sooner. I was at work when I posted. Had to come home and do some honey-dos. Tank was half full or better. Tried going forward, no problem unless I had a big load. Tractor has been great since I bought it. I had a problem with the battery going down. Kept reading the board. Replaced the battery before I read about the alternator belt. Yep, mine was loose. Trying to devise a bracket to use to tighten up the alternator. My tractor doesn't have one. Thanks guys, I'll keep trying.
Bob in NY
06-08-2002 20:45:10
 Re: Re: Re: Re: 8N grading in reverse in reply to Sam at classic manor, 06-08-2002 18:42:09
Had a bunch of honey do's today too.
I have a 2N, and I put on a GM alternator.I put a bracket under a bolt on the governor, and hooked a heavy spring to it, and the other end to the alternator. Works reasonably well, but need to find a stronger spring. Bob in NY
