Lean Idle
RobTex
06-14-2002 06:03:42
I have an 8N with front mount distributor. It never has idled well. The carb was worn out so I replaced it with one that
I bought from Don. It helped the responsiveness
and runs well had high RPMS and under load
but still idles rough. It prefers the idle
mixture screw all the way in but it really has
very little effect no matter where you put it.
The idle smooths out and speeds up when you pull
the choke out just a little.
Sounds like a vacuum leak, so I replaced the manifold with a new one. That didn't change it at all. I've rechecked ignition timing even
though I can't imagine how that would effect it.
I put a vacuum gauge on it, when I had the old
manifold on, and the needle jumped around a little but I don't think it is enough
to indicate leaking intake valves.
Anybody got any ideas?
By the way, my rotor is somewhat loose on the
distributor shaft. You can turn the rotor a few
degrees before it starts turning the breaker
cam. I've tried 2 rotors. Is this common?
Also, one of the rear tires is leaking clear
fluid. Is calcium chloride clear? I'd prefer
not to have CaCl in the tires because of the
corosion but need some weight for traction.
Thanks in advance. This discussion board has been a big help
to many of us.
Danny in CO
06-14-2002 08:47:20
 Re: Lean Idle in reply to RobTex, 06-14-2002 06:03:42
With the rough idle, my GUESS would be an air leak somewhere: between the carb and manifold or between manifold and block. Try spraying WD40 around these places. If the engine speeds up, you have an air leak at that place.
Danny
ZANE
06-14-2002 06:46:54
Taste the clear liquid coming out of the tire. If it tastes like salt it is Calcium Chloride. Get it out and rince with lots of water.(Lots) Probably is something that will neutralize it but I don't know what is may be.
The Marvel carburetor is a great little example of early engineering and will last forever but the idle mode is lacking to say the least.
I don't know which carburetor you got from Don but if you got an original Marvel it is probably a rebuild and it may need to be lapped between the two halves of the carb. If it is a look alike it may never idle. They are even worse in the idle mode.
Here is a file I have on lapping the Marvel to acheive best idle.
In order for the Marvel carburator to idle the gasket that goes in between the bowl and the throat of the carb. Where the two surfaces mate must seal completely this surface is sometimes not finished very good on the marvel and their may be some uneveness around the edge of the two mating surfaces especially if the carb has had a few too many brogan adjusts.(pecked on with various and sundried things to stop it leaking etc. These mating surfaced can be leveled by Lapping them on a good sheet of about 100 grit wet or dry sand paper laid on a flat solid surface. The tow small blind rivets that hold the float hinge to the carburetor housing must me pried up so that the hinge bracket can be removed. Use a figure 8 motion till all the bumps are gone. You can also do the same thing with a large flat file but it won't be as flat as lapping.The object is to prevent any air leak where the idle Passageway connects between the two surfaces. If you get this sealed properly it will idle.The passageways also must be free of any foreign materials. The best tool besides compressed air that I have found to clean out the various size passages and orifices is a welders tip cleaner plus compressed air Added on Date: 15:49:36 1/27/99
RobTex
06-14-2002 07:14:28
 Re: Re: Lean Idle in reply to ZANE, 06-14-2002 06:46:54
Zane, the carb is a new look alike.
Does anybody out there have a look alike that idles smooth at low RPM?
I'm hesitant to taste something that I don't
know what is. If I could get one of the cats
to do it, I wouldn't mind loosing one of them,
but I still wouldn't know if it was salty
or not:) Maybe I'll test it myself. If Zane has done it, I might live through it.
Have you noticed if it is common for the distributor rotor on a front mount to be
slightly loose?
don b
06-14-2002 08:30:11
 Re: Re: Re: Lean Idle in reply to RobTex, 06-14-2002 07:14:28
Rotor should not be loose and your engine is getting air from someplace.Keep looking. don
