Order Ford 8N Parts Online
8N carb problems
8N?9N
06-17-2002 12:34:19
Working on a 52 8N for a woman and the only way it will run is with the choke out I have cleaned the carb and have good fuel flow from the tank. Could it be a leaking manifold gasket. Carb did need cleaned but is in good shape otherwise. It has me stumped as I have poked and cleaned every hole in it and it still won't run without the choke out. Thanks in advance for the help.
8ndonmd
06-17-2002 14:15:06
 Re: 8N carb problems in reply to 8N?9N, 06-17-2002 12:34:19
How about Adjusting the hi speed adjustment on the carb. ( The Big Knurled Knob). Should be about 1 1/2 inches out Approx!
MikeC
06-17-2002 12:52:07
Have you done the "test" for a leaky manifold gasket (spray WD40 around it)? Try it and let us know the results. Could it also be the halves of the carb body need lapped?
8N?9N
06-17-2002 12:59:36
 Re: Re: 8N carb problems in reply to MikeC, 06-17-2002 12:52:07
Ok will try that next cant figure what else it could be thinking of taking the carb off of my 8N and trying it but hate to do it mine is running fine
