Order Ford 8N Parts Online
Wiring Diagram 8n
Pat D
06-17-2002 13:54:00
Well here I am again. My 8n wiring harness is trashed. I can't trace anything for sure. It has a side mount dist, has been converted to 12V. The ign swith is three pole but has not starting position. The seller told me to start it by jumping both sides of the solenoid. The alt has two terminals and is not the induction type. Where can I get a start from scratch wiring diagram including gauges of wire to use. Thanks for your help on my thermostat question
Rusty
06-17-2002 14:17:09
 Re: Wiring Diagram 8n in reply to Pat D, 06-17-2002 13:54:00
www.nseries.com/wire.asp
Bob W [FL]
06-17-2002 14:15:55
Go to the following link and find the diagram you need 12 volt or back to 6 volt. It does not give wire gauges.
PatD
06-18-2002 04:47:54
 Re: Re: Wiring Diagram 8n in reply to Bob W [FL], 06-17-2002 14:15:55
Thanks for the info guys. In the 12 volt conversion diagram, why is the voltage regulator missing. Do you know what the part number for the terminal block is. Is this the one with the resistor to reduce the voltage to the coil. Thanks
SteveB(wi)
06-18-2002 05:21:58
 Re: Re: Re: Wiring Diagram 8n in reply to PatD, 06-18-2002 04:47:54
Assuming your twelve volt conversion is an alternator not a generator the alternator has an internal regulator.
Pat D
06-18-2002 10:02:48
 Re: Re: Re: Re: Wiring Diagram 8n in reply to SteveB(wi), 06-18-2002 05:21:58
Steve; Thanks for the response. The fog is starting to clear. How do you tell if the charging device is an alt or a generator. It is new and looks like a car alternator. It has two terminals, one a plastic clip with two wires and another marked "R" or "B".
Dell (WA)
06-19-2002 03:56:17
 Re: Re: Re: Re: Re: Wiring Diagram 8n in reply to Pat D, 06-18-2002 10:02:48
Pat..... .....generators are round starter sized things that need external square voltage generators, alternators are aluminum car looking things with built-in voltage regulators.
You have described a typical Delco 10-SI 12 volt alternator. The big stud with a "B" supplies 12 volts out to the battery, usually by connecting to the starter solenoid battery terminal because it is convieniet.
One of the plastic clip 2-terminal plugs is called the remote voltage sense (P-2) and is supposted to be connected to the alternator "B" output. (short wire)
The other terminal (P-1) is the exciation is usually connected to the ignition switch by a markerlight being used an "idiot light" just like GM does on its cars. If you don't use some sort of decoupling, you'll never get your tractor engine to turn off because the alternator P-1 will backfeed power from the alternator gutts and send it to the ignition coil..... ..... Dell
